LandYacht35dies's avatar
Oct 12, 2021
Handling “hard dried stuff” in the black tank ?
..... anyway to SLOOOOWLY dissolve it and rinse it away ?
  • You can, if you have time, put a quart of home septic tank treatment in the tank with a quarter fill of water. Let it sit for two weeks and drive. You could add the ice and then drive, but all that enzyme treatment should have eaten it all up. Did this to a fully clogged tank and it was so clean the OEM tank level system worked for the next five trips like it did when new.
  • Buy some ice, like at least 30 lbs worth. Dump it down the toilet into the black tank. Add a little water. Also pour down the hole a lot of liquid laundry detergent. Then, go for a spirited, bumpy and curvy road drive. Afterwards. let it sit for an hour or two, then dump. That should get all the petrified poop out.
