dougrainer
Feb 15, 2019Nomad
Bubble like the OP has is NOT always caused by water intrusion on a NEW unit. It is just a defect in the filon and the adhesive. We see this numerous times each year on trailers and motorhomes. The fix is simple for a Body specialist. You cut out or grind out the affected area, Once that is done you will know if there is water intrusion. You then fill the cavity in with fiberglass and sand and then paint blending it in with the surrounding area. Winne will pay for this. Getting a new motorhome for this type problem? NEVER. The warranty states that The OEM is allowed to repair or replace items that are determined to be defective. Doug
