hootgipperExplorerFeb 13, 2019Hard baseball sized "bump" outside RVHave a 2018 Winnebago Intent 26M, purchased Aug 31, 2018. We've only used it a couple of times. It has spent almost a total of 2 months "waiting" or getting warranty work done. An area near the tailga...Show More
tarnoldExplorerFeb 15, 2019Could you heat the area with a hair dryer, inject some epoxy through a small pin hole then apply extended pressure till the epoxy sets?
Related ContentNo power on outside GFCI outletAir bags or "Bump Stop" type suspensionHow to correct uneven "Bump Clearance" ?Hit a Speed Bump then "Crunch"Tekonsha P3 any good with "Hensley bump"?
