What's the best way to remove hard water stains from the side of your coach? I get some periodic dripping from refrig venting and from roof air conditioners that run down the side. Leaves a white stre...
Don't know if it will work but how about Mr. Clean magic eraser? Clean out the gutters and raise the front/back slightly higher to allow the water to run off. For the Refer drain can you put a spacer between the hose and wall so the water doesn't run down the wall. P.S. we don't seem to have this refer problem.
