- VA-ApraisrExplorer IIThank you sir! Definitely follow up on your lead. Safe travels!!
- ferndaleflyerExplorer IIIApraisr I have a friend that lives in Glen Allen---small world as I come through there often. I'll soon be 81. Sure would have been nice to know you a couple of years ago as I sold a whole Blue Ox set up for $250 that came with my current DP. You snoop around you can pick those up cheap used--just keep looking. Sent you a PM
- VA-ApraisrExplorer IIFerndaleflyer: I have a good quality tow dolly as well.....just a pain in the $$S to move it around and find a storage space for it. And I'm 61 and workout every single day :) but that's a workout I do NOT enjoy (hence, the info for an upgrade!).
- ferndaleflyerExplorer IIIBobnDot not trying to start a debate on this but--You speak of maintain on the dolly, couple of squirts of grease now and then and the bearings are good. I have never changed them in over 50,000mi, no registration, or inspection, I store it in the garage at home and have hardly ever had to unhook it in a campground. New tires once. And it works for all our front wheel drive vehicles year after year. And the dolly has its own lights. Sorry I hijacked the OPs thread and as I said before to each his own
- bobndotExplorer IIIOP, if i click my ignition to ACC position , first click before “on” , to unlocked the steering wheel, the toads mileage will NOT register on the odometer. If i accidentally click it to the “on” position , miles will register.
- bobndotExplorer IIIDolly : As long as you don't mind to maintain a dolly that’s fine.
Brakes, tires, wheel bearings, registration, inspection , storing the dolly at home as well as a campsite. Some find it too much to do.
OP, as said depending on the toad , the 7 way plug has to be wired by you. You are adding an empty plug for your lights. Add a charge line besides the toad lights if necessary.
In addition to the 7 way plug :
Depending on the toad make/model, you might need a lighting harness in order for the lights to function as normal.
I skipped that step and drilled a hole in the taillight housing for my own rear lights, a socket and bulb. No harness needed.
Not a big deal to do either way. The mechanic that did my setup said it was easier and less time to socket and bulb it. However, that ‘only’ offers you rear lights on the toad, running, brake and directionals. No side marker or license plate lights.
For that , i just turn the toad parking lights on.
That’s another reason for a charge line installed on that toads 7 way plug. Make sure you use a fuse where needed. - CA_TravelerExplorer IIIThe use of a charge line depends upon the toad battery discharge when towed. My Jeep doesn't use any power when towed hence a charge line is not required. Other cars vary even when the ignition is off.
In my opinion the draw from an auxiliary brake is limited and a charge line is not normally needed, but your mileage may vary. - ferndaleflyerExplorer IIIReading all of this makes me glad I have for 15+ years used a $700 (at that time) dolly that has served several cars and only other expense was a set of new tires. I am now 80 years old and can hook that mess up in 10 min. But I understand some would and do feel different.
- larry_cadExplorer II
VA-Apraisr wrote:
On more question: many mentioned running a wire to help keep tow vehicle battery charged from the RV alternator system. Assuming this is since the tow vehicle ignition is on the "ON" position the whole time while traveling? So, the 7-pin hookup does NOT account for this, right? I was going to have my brother assist with this if and when I go this route, and just wanted a heads-up.
The auxiliary brake mechanism also uses electricity from the battery. On a long trip, it can run the battery down. The "hot" wire will help keep the battery charged. The 7 pin plug should have a hot wire in it. - VA-ApraisrExplorer IIOn more question: many mentioned running a wire to help keep tow vehicle battery charged from the RV alternator system. Assuming this is since the tow vehicle ignition is on the "ON" position the whole time while traveling? So, the 7-pin hookup does NOT account for this, right? I was going to have my brother assist with this if and when I go this route, and just wanted a heads-up.
38,782 PostsLatest Activity: Sep 20, 2026
