mtrumpet
Apr 27, 2016Explorer
Well, back when we had our gasser on a Ford F53 Chassis, I installed a Davis TruTrac on the front and a Henderson Rear Track Bar on the rear. However, both came with bracketing that matched up with pre-drilled holes that were already in the frame from the chassis manufacturer. So, it was basically just bolt them up into place. Isn't your 2011 Tiffin Allegro 35QBA setting on a Ford Chassis? If so, you could get bars that will fit the pre-drilled holes in the frame as I did.
Henderson Track Bars for Ford F-53 Chassis
Davis TruTrac Front sway bar for F-53 Chassis
Now, if you have to drill into the frame, that gets a lot tougher.
38,778 PostsLatest Activity: Jun 05, 2026
