btcruzer
Apr 28, 2016Explorer
drilling slow and use lube is good advice. Pref. use a tool with an adjustable clutch. Also make sure the tool has an aux. handle. Drill a small pilot hole and then use a "step drill bit" to get to the desired hole size. The " step bits" don't hang up nearly as bad as a regular bit. Take your time and plan this out. In the long run, slow and steady is faster than a detour through the emergency room. BTY my fractured wrist is healing nicely.
38,778 PostsLatest Activity: Jun 06, 2026
