wallynm wrote:
Water weighs in at 8.5 pounds per gallon. 4 _ 500 pounds will do it on some rigs when fully loaded. I suggest most folks have idea as to what they weigh going down the road. Do you?
They did not have a tag axle Liberty
Mr.Mark wrote:
LynnandCarol, I'm just trying to understand how a full grey tank pushed you over your CCC and weight for the tires. How big is your grey tank?
MM.
Wallynm, you are right, they said they had a TT. Either the tires were under inflated or the axles are under rated for the TT. A full tank should not push them over but it apparently did. I would want to know my exact weight if it was an issue.
And, they didn't check the tank levels? I guess I check everything before departure and I know some things can be missed.
Hope the OP has better luck on their next outing.
MM.
