RoyB
Jul 20, 2015Explorer III
In my FIFTH WHEEL I was able to pull down each of the Air Conditioner ceiling vents and pull some wiring from vent to vent (every six feet or so) from one end of the trailer to the other. I used the spray foam to seal-up any holes I had to make getting in and out of the cut-in a/c ducts.
Usually on both end you will have ceiling cabinets installed where you can retrieve your cables and route to where they need to go on both end behind the thin walls.
Being a HAM RADIO guy I ran several RG type cables down the air conditioner cut in ceiling ducts...
The other route is under the trailer which has a closed membrane that has to be removed first.
I guess you could consider BLUE TOOTH as well
Roy Ken
Roy Ken
