msmith1199
Jul 20, 2015Explorer II
TNGW1500SE wrote:msmith1199 wrote:
I ran an HDMI cable through my duct work and it works just fine. I have a duct running the length of the coach on both sides however. I would assume you could cross over at the A/C unit if you need to.
Just got to take a look at it again. I took off the A/C return duct and I can just run the cables from one side to the other side of the duct work. I will have to bring the cable out of the ceiling back by the bathroom but I think I can just cover it with wood trim. I have some matching panels.
I don't know what your set up looks like, but what I found with mine is that even though the last vent on both the front and the back was a few feet from the cabinets, the ducts themselves actually went all the way to the end of the roof. So I was able to drill a hole from inside cabinets in both ends and feed the cable through it so the cable is completely hidden.
Before somebody on here gave me the idea to use the AC ducts, I had planned on buying a beige colored cable cover. I was just going to screw it to the roof and run the cable through it. I didn't completely like that idea, but between ac ducts and roof vents and ac intakes, there is so much stuff on the roof I figured it wouldn't stand out that bad. So that's another option. I also looked at the wireless transmitters and I was only going to do that as a last resort.
38,782 PostsLatest Activity: Sep 10, 2026
