Daveinet wrote:
WILDEBILL308 wrote:
You may want to do some more research on that stamen. Banks, Thorley and Gibson are almost the same design and all work well for a motor home.
Bill
Every bit of research I have been able to find that compares Tri-Y to long tube headers shows the Tri-Y perform much better in the midrange, as well as the "low" top end. Look at any Dyno graph comparison, and below 4500 RPM, the Tri-Y out perform long tube on the same engine, same test. Basically the wide RPM boost starts in the low mid, and carries out to above 4K. My seat of the pants also confirmed this, once I finally got decent mufflers. There was a huge boost right out of the hole.
I'm am a little curious that you state that Banks, Thorley, and Gibson are all the same design. How can they be the same when one is Tri-Y and the other is single long tubes?
Banks, Thorley and Gibson are all designed to provide lower end torque and horsepower. All 3 use a “long tube” header designs. If you are concerned with under hood heat go with the ceramic coated ones or wrap them.
Bill
