mikeleblanc413's avatar
Mar 13, 2014
Headlight Kit Replacement
RE: 2000 Winnebago, Minnie Winnie, Ford E-450.
Looking to replace my foggy looking headlight and would appreciate fa supplier recommendation. From what my mechanic showed me, it's basically a plug and play. Not interested in buying from EBAY1
  • mikeleblanc I would be very interested in the details of the change. I was just about to order a set as well for the same reason. if you don't mind that is.
    He showed me two pull up clips on each end of the top of the light. Pull each clip up (he had to use pliers on one), be sure to be holding the light, unplug the connection. Reverse the process and it's a done deal. Took him maybe 5 minutes. Hope this helps.
