Paul_GuentherExplorerMay 18, 2023Headlight only works on high beamMy passenger side headlight only works on high beam on my 2002 Tiffin Zephyr. Driver's side works fine. Have replaced the bulb. Any suggestions will be appreciated!
CA_TravelerExplorer IIIMay 18, 2023Assuming the new bulb is OK then it's most likely a wiring connection between the two bulbs,
Related ContentHow to adjust LED headlights?Not all Aftermarket bumpers work2003 newmar freightliner speedometer stopped workingLow beams headlights not workingSensitive headlight sensor
