Paul_GuentherExplorerMay 18, 2023Headlight only works on high beamMy passenger side headlight only works on high beam on my 2002 Tiffin Zephyr. Driver's side works fine. Have replaced the bulb. Any suggestions will be appreciated!
wa8yxmExplorer IIIMay 18, 2023I oncce had a connector with a bent pin.. It did not go into the socket properly. Straightened it and all good.
Related ContentHow to adjust LED headlights?Not all Aftermarket bumpers work2003 newmar freightliner speedometer stopped workingLow beams headlights not workingSensitive headlight sensor
