dougrainer
Jan 12, 2021Nomad
The simple answer is-----The OLD Heart Inverter/Charger and current products do NOT let the battery charge drop at all as long as you are plugged into Shore Power. The Inverter/Charger will MAINTAIN the existing 12 volt power. It should never drop to 10 volts unless you are disconnected from 120 power and drawing 12 volt current. Now, while you could have the Heart serviced or fixed, it is not cost effective on a 22 year old Inverter/Charger. I would not worry about it until the 12 volt system dies when the Heart finally completely fails. IF you decide to replace, there is NO plug and play replacement. You will have to change the Inverter/Charger(It is called Xantrex now) and the remote wiring harness and get a new remote. Your old remote only works with the Heart, not with the newer Xantrex models. Doug
38,782 PostsLatest Activity: Sep 02, 2026
