Hi,
To the OP, set the dash heater on defrost--the heat will go over your head to the rear of the RV.
To bfast54:
Use an oil filled heater. No risk of fire.
I run some electric heating via the inverter, and have in the distant past run a generator to power them. Why? Because where I RV propane for filling a class C is often only available in small to large cities--and not at all in small towns.
To Gary:
There you go making me jealous of your RV (again).
bfast54 wrote:
you think it MIGHT be better to run the generator and an electric space heater which by the way could fall over and start a fire ?????? ?...While driving down the road....
this is correct.....:h
