mobileempire
Jan 12, 2014Explorer
Heat water with Propex heater?
I'm using a Propex 2800 heater to heat the van and all is working well but
I need something to heat my water to keep it from freezing , normally I've been just setting my 5 gallon water jug in front of the Propex until the water reaches my desired temp , this has worked so far but as the temps outside dropped below freezing I started thinking about building a insulated box and then pipeing in a tube from the Propex , is this a good idea or would I better off getting a propane powered water heater?
I would like to keep everything as simple as possible , less wiring and less Plumbing etc.
