Rover1995
Mar 09, 2018Explorer
Heated floors
Looking to upgrade to a Tiffin Bus all electric and wondering the pros and cons also heated floors pros and cons. I live in North Idaho and store my RV out doors and how the heated floors are in cold
dougrainer wrote:Mile High wrote:
Tiffen uses electric heated floors. Entegra actually uses the AquaHot to heat the floors.
Either way - I would get them if available! They weren't available for us and those tile floors can get down pretty darn cold in the morning :)
There is a difference between HEATED floors and what Aqua Hot does. Aqua hot is NOT a Heated Floor like people think you mean. Aqua Hot just has their floor mounted Radiators with the muffin fans blow hot/warm air ACROSS the floor at the floor level. NOT close to that 14 inch wide radiator and the Floor is NOT warm/heated. True heated floors have a 120 volt heat grid under the Tile floor and radiate the heat evenly thru out the Tile floor. While Entegra advertises they use Aqua Hot to heat the floors, I think that is a misleading statement. I researched this because I thought Entegra was running coolant lines in a grid under the Tiles. NOT a good idea as leaks are bound to happen. I found out they do not, they use the Radiator system to flow the heat across the floors. Doug
