CVDExplorerJan 02, 2017Heater Core Replaced, Now Blows Cold AirI had a leaking heater core replaced on my 99 Winnebago with a Freightliner XC chassis. No more leaks, but now the dash heater only blows cold air. I suspect my local truck repair guy (who knows hea...Show More
I_rvExplorerJan 04, 2017pull that green vacuum line off water valve, no vacuum gives full heat,you should see actuator arm move if not valve is stuck
Related ContentReplace insulation inside heater column.Water Heater Replacement RecommendationsReplacement Lights for TTAtwood water heater problemAtwood Water Heater Blowing Fuses
