Fla904ExplorerDec 03, 2015Heating RV problems.Does the RV ac unit also heat the RV? When I put the thermostat to heat it only blows out cool air? I'm a not turning something on?
HealeymanExplorerDec 03, 2015Fla904 wrote:I'm a not turning something on?In most class Cs, the A/C is on the roof and the furnace is near the floor, often under the refrigerator or the sink. They are two separate systems.Make sure that you have propane in the tank and the valve on the tank is open.Try lighting the stove. That will tell you if you have usable propane or not.If the stove lights, make sure that the thermostat set temperature is above the ambient temperature.Tim
Related Contentheat causing problems inside RVTroubleshoot fridge problem...Heat Pump problemsAtwood water heater problemNo Central Heating
