Fla904ExplorerDec 03, 2015Heating RV problems.Does the RV ac unit also heat the RV? When I put the thermostat to heat it only blows out cool air? I'm a not turning something on?
tenbearExplorerDec 03, 2015Mine has separate AC and furnace, both controlled by their own thermostat. The heater works off propane.
Related Contentheat causing problems inside RVTroubleshoot fridge problem...Heat Pump problemsAtwood water heater problemNo Central Heating
