Fla904
Dec 03, 2015Explorer
Heating RV problems.
Does the RV ac unit also heat the RV? When I put the thermostat to heat it only blows out cool air? I'm a not turning something on?
It would help if we knew what RV you have. (If you put that in your signature or on your profile page, one could look it up, if you didn't include it in your post.
As already stated, not all RV's come equipped with air conditioners that will also heat - that is, not all are heat pumps or have heat strips.
Perhaps the thermostat, when set for heat, should turn on the propane furnace. Let us know how you turn on the propane furnace.
Tom
