Fla904ExplorerDec 03, 2015Heating RV problems.Does the RV ac unit also heat the RV? When I put the thermostat to heat it only blows out cool air? I'm a not turning something on?
pconroy328ExplorerDec 03, 2015If you're willing to plug in for heat, then I'd toss in a small, electric heater before I'd bother with a possible but unlikely heat strip in AC unit.In the winter here, I've used one of those $39 Oil Filled Radiator electric heaters in ours. Works very well.
Related Contentheat causing problems inside RVTroubleshoot fridge problem...Heat Pump problemsAtwood water heater problemNo Central Heating
