Fla904ExplorerDec 03, 2015Heating RV problems.Does the RV ac unit also heat the RV? When I put the thermostat to heat it only blows out cool air? I'm a not turning something on?
midnightsadieExplorer IIDec 03, 2015open the propane valve slow, then go light the stove, if you open the valve real fast you could trip the safty.
Related Contentheat causing problems inside RVTroubleshoot fridge problem...Heat Pump problemsAtwood water heater problemNo Central Heating
