OFDPOS wrote:
If memory serves me right ? That would be the front Anti sway bar !
If so GET the torque specs if you can, the rear bolts are smaller then the front bolts.
I,,, NOT torquing to specs when I installed the Anti sway bar,so when I went to remove the bolts to install the Safe-T-Plus steering stabilizer bracket pulled the threads right out of the threaded hole on the drivers side.
Had to re-tap the hole...
Yep, I had to look it up. Always best to state Year, Make, Model...
Uh Huh... an OP here upgraded the Axle on a 2006 E450 so he ordered the 7718 sway bar. Then found the front bolts were bigger. Decided to enlarge the front holes to the newer size... Buggered them, had to call in a welder...
I was sure if anybody had the specs, you would...
Which makes you the second OP with trouble about those holes...
Or the third - One of us couldn't get the late model big bolts loose...
j-d's Hypothesis: Something is wrong with Ford's assembly technique on the front bolts in 2008 and newer. Hole is wrong, bolt is wrong, over-torqued or hole galled. Next guy who puts a wrench on one has problems. We've had too much of this on late models, after nothing on older ones...
