Yep , nope didn't get the trq specs, but also didn't over tighten the rear smaller bolts first time around,,, er I at least I thought I didn't ! lol
But when I removed it to install the steering stabilizer the threads came out with the bolt.
On first time around removing the stock Anti sway bar , the front bolts I couldn't even get them loose with an impact gun.
Literally had to use 3/4 breaker bar with an impact socket and a cheater pipe on the breaker bar to get both sides front bolts out.
They were tight all the way out..
Funny thing , they hand screwed back in.
The smaller rear bolts were tough , but nothing like the front ones.
The frame is just drilled and threaded for the bolts , no extra support , nut etc just 4 maybe 5 threads to hold the bolt.
Plus the frame is boxed so you couldn't get in there and add a nut , unless you wanted to tear alot of the front end off to get access ...
I know I'll get flamed for this comment , I feel Karma has already visited me as it is.
I am NOT a ford fan ...
I know its been years , but working at both GM and Ford dealerships service depts and what little I've worked on both , Gm has it right on a lot of stuff over Ford...
