Spizzer
Aug 26, 2014Explorer
I have a Journey that does the same thing intermittently. There are five things that are in the circuit on mine (07). The ignition switch energizes a relay in the front relay panel. that signal travels to the back of the coach. In a chassis relay panel in the back, there is a relay that is energized when the transmission is in neutral. this allows the signal to then travel to the starter relay which closes allowing a current from the batteries to go to the starter.
My chassis relay panels are in the drivers side in the last bay with the shore power. On the left side there is a plastic cover held on by a few nuts. Inside is a huge relay tower, which is the last one in the path before the starter. It has to big cables on the top and two smaller ones at the base. The smaller ones are the ground and power coming from the transmission relay and front relay and ignition switch. If you jump across the to large terminals with a screwdriver, the engine will crank if the battery and starter are good.
I have not been able to trouble shoot mine as it always happens when I don't have the luxury ....like right after I have filled up at a station, etc. So I just grab my screwdriver and start it. It won't happen again for maybe 50 starts. We just took a 5 week trip this summer and it happened one time. The first time it happened it was dark and I was sitting in front of the registration office at a campground. Freightliner tech support talked me through the jump start to get me going. Didn't happen again for some time.
Before you do start it, throw a meter on the line coming to the relay and see if you have power when the ignition switch is turned to start. The transmission relay is on the right side of the bay behind a metal panel held on by a bunch of screws....not a quick removal. I left mine off for a long time waiting for a chance to trouble shoot but eventiallly put it back on.
Good luck. If you need pictures of what mine looks like, let me know.
jeff
jeff
