wildmanbaker
Mar 07, 2019Explorer
OK, first check all of your fuses for the chassis. Don't just look at them, actually remove and test them with a VOM. Do you have separate brake and turn lights, or does your MH use the same light for both the brake and turn lights? If it uses the same light, you do not need an converter. The fuse panel you are looking for is probably on the dash in the drivers side.
Oh, and welcome to the forum.
38,769 PostsLatest Activity: Apr 03, 2026
