dougrainer
Mar 09, 2019Nomad
OK, The adapter only is for the Left and right turn and Brake lights. The running lights should still work. If the running lights do not work, then either the 7 way at the hitch is unplugged from the Ford Harness or you have NOT found the fuse box up front for the Tow plug wiring. Usually on Ford Chassis's the fuse block is accessed from the front outside hood and is mounted on the outside firewall in front of the drivers seat. Doug
38,769 PostsLatest Activity: Apr 03, 2026
