carringb
May 30, 2014Explorer
Check for major vacuum leaks. This affects the ability of fuel pressure regulator to function (as well as the idle air controller).
Once you rule that out, you probably need to verify fuel pressure. If you have never changed the fuel pump before, you'll probably need to.
38,776 PostsLatest Activity: May 15, 2026
