Southwind98
Aug 26, 2016Explorer
After a little investigation this morning I found the corner of the outer metal floor was loose and was causing low clearance on one side. Still need to adjust height but when the slide is closed the clearance is great in the back, but decreases going forward because of a tilt. Once the slide is engaged to travel out it tilts forward even more for half way thru then rocks back before it descends down the hill.
