onrecess
Sep 14, 2016Explorer
It is my friend's. It is awaiting repairs. There is a 4x4x2 white control box in the corner by the motor. There are bolts on the front (coach front) of the trim in front of rear lifts. Supposedly, switching off rhe brake frees the bed for two people with ratchets (none will fit - we had to go buy ratcheting wrenches) to crank it up. With the plugs pulled we finally got the brake released. That worked... until the first bump where the bed dropped down! We had to reach up in that driver corner and find the plugs and put the brake back on.
It is a terrible design in every way. The panels are a puzzle, ratchets don't fit (even 1/4 drive), and you can get a 1/8th of a turn on the wrenches. Oh, and it takes two or it would be a two hour job (1/8th of a turn and a couple of minutes working the wrench into the impossibly tight spot on other side about 100 times. Pray it never breaks!
