kalynzoo
Oct 12, 2013Explorer
Depends on what you call expensive. But after rocking the rig with the jack down I would certainly want a competent tech to inspect the welds on the jack and the piston. Next time, if your raised and the weld fails the results could really be expensive and dangerous.
A replacement jack can be costly, however, on the HWH jacks sometimes the spring just becomes warn, like and old garage door, and does not have the force to bring up the jack. Or, there may be a plug in the hydraulic line than can be service. It's worth having it at least checked out before it breaks.
JMHO
JMHO
38,766 PostsLatest Activity: Jan 10, 2026
