Gjac
Oct 15, 2013Explorer III
If you post what system you have it would be easier to get more specific replies. If it is the HWH 200 or 210 series the jacks will not be damaged by rolling backwards. This happened to me when I pulled into a campground after dark and the site was not level and I rlled backwards off the jacks and could not get the to retract all the way. I called HWH and they assured me they were designed to rolled fwd or backwards without damage. After cleaning the dirt and sand out of the outer seal and the shaft I was able to get them to retract. Is the green power light lit on your panel? Does the red parking light come on when you push the emergency brake on? If not you can start by checking the 5 amp fuse located in the control panel itself.
38,766 PostsLatest Activity: Jan 10, 2026
