golfman_1ExplorerOct 26, 2015help gen problemOnan 7.5 gen. Will start and run. When you start coffee pot, microwave, a/c it shuts off., Only code was 22,not enough power. What could be problem?
2oldmanExplorer IIOct 26, 2015If you start those 3 items in that order, there isn't enough power left to start the air con, which takes a whopping amount of power to get started.If you've done this in the past without problem, then the generator needs servicing.
Related ContentAtwood water heater problemGen?Troubleshoot fridge problem...Norcold Model 611 Fridge problemGen Y Hitch
