dougrainer
Sep 09, 2021Nomad
fijidad wrote:
Well, I think I'm in the final leg of this issue...I've spoken to Senior Member Jerry Parr, and Richard, a retired mobile RV mechanic, in pursuing why our fridge wouldn't operate correctly. Jerry suggested I call Norcold and run this by them. I did and they said if the red light on the Recall Kit black box was on solid, then that box was probably bad. They said go to Camping World and order a new one for free. I did and now I'm waiting for it to arrive. In the meantime, Richard suggested connecting the two 12 volt wires from that box together...basically they way it came from the factory...I did and now the fridge works fine in every situation. I asked the Norcold rep. how long the Recall Kit boxes are good for...she said some last 10 years, and some much less. I think mine had a couple of different phases of failure, as the symptoms changed a bit over time, but I'm a happy camper now that I tracked it down to the Recall Kit.
IF the recall box is installed correctly, it will show LiOP when the red led light on the box comes ON. You NEVER stated that the RED LED on the recall was ON. Also, the most common cause of a failure of the recall box is if water gets into it when washing the RV and blowing water thru the refer out door. IF the recall light was ON and you got NO AC on the inside, the recall wiring is NOT installed correctly. Doug
38,782 PostsLatest Activity: Sep 19, 2026
