stardalo
Jul 14, 2013Explorer
I have an 03 Journey. I think you need to relieve pressure in the hydraulic lines then manually pull in slides. To do so, I believe the directions are in your spiral bound winnebago manual. But what it basically says there are 6 soleniods, 4 for jacks that have a t handle on them and can be turned with that and 2 for the slides that you will need a nut driver for. I believe they are located on driver side towards the back of your basement compartment. You have to push rear in and for the big slide, i believe the winch goes in the floor heat register and connects onto some seat belt like straps and then you slowly pull in over 10 minutes or something like that. Good luck.
38,768 PostsLatest Activity: Nov 21, 2015
