JAXFL wrote:
Thanks guys the Georgetown is coming close. I need the drivers door so that when I park next to the house I can get out of the MH. The park space in only 9' wide except where the drivers door would be and that is 13' X 9' so I can get in and out at the point but no where else along the whole fence and house.
The specs on the Georgetown say that it's a 101 inches wide. It will be mightly close with little room for error. That will give you just shy of 6 inches to work with (<3 inches on each side?).
Good luck on your search!
On edit: Also, if your pad is not level, at 12'7" tall (the 37' Georgetown is an inch shorter than the other models), you could hit the house or fence if it leans.
MM.
