Mr.Mark wrote:
JAXFL wrote:
Thanks guys the Georgetown is coming close. I need the drivers door so that when I park next to the house I can get out of the MH. The park space in only 9' wide except where the drivers door would be and that is 13' X 9' so I can get in and out at the point but no where else along the whole fence and house.
The specs on the Georgetown say that it's a 101 inches wide. It will be mightly close with little room for error. That will give you just shy of 6 inches to work with (<3 inches on each side?).
Good luck on your search!
On edit: Also, if your pad is not level, at 12'7" tall (the 37' Georgetown is an inch shorter than the other models), you could hit the house or fence if it leans.
MM.
AND remember (since we had our driveway redone to accommodate our MH) the awning comes out a tad as do the pipes. Plus the roof of your house might jut out. We are able to get it in and couldn't go any wider because like you we have a neighbor so we just fit.
