dcbrewer
Oct 21, 2013Explorer
Help no heat
Our heat won't come on. The AC cooling side on thermostat works but the heat side won't come on. At first the #1 unit was all that would work on cooling and now the # 2 unit will work on cooling also,...
dcbrewer wrote:
Our heat won't come on. The AC cooling side on thermostat works but the heat side won't come on. At first the #1 unit was all that would work on cooling and now the # 2 unit will work on cooling also, but will not work on gas heat or heat pump and it is cold, here in Gatlinburg. Need help!!
