elhajj33's avatar
elhajj33
Help! No power to Jenn-Air cooktop
This doesn't make sense. I have a Jenn-air cooktop in my 09 Fleetwood excursion. The outlet it is plugged into isn't getting power.
I know this because there are two outlets under the sink: one for the dishwasher and one for the cooktop. If I switch the plugs, the cooktop works and the dishwasher won't power on.
The EMS is working fine. I tried using the generator but still no power.
We're on 50amp shore power and I can't think of a reason why it's not getting power. I checked and cycled the breakers and it's not that.
Any thoughts??
  • rgatijnet1 wrote:
    Did you check the breakers on the INVERTER itself?
    These are not the ones in your main electrical breaker box. They are right on the inverter and I'd suspect that one of them has tripped.
    I haven't checked that, but I did confirm one thing: the outlet is shutdown when the washing machine is on. Power returns when the washer/dryer completes its cycle.
    I'm starting to suspect something is up with the EMS
  • Quick update on this: according to intellitec there's most likely an energy management select switch somewhere near the washer since the circuit is a 15amp circuit and wouldn't be ale to handle the dryer and washing machine at the same time:
    http://www.intellitec.com/index.php/products/Energy_Management/Smart_energy_management_systems/Automatic_energy_select_switch
