Dutch_12078
Jan 17, 2021Explorer III
Kennyg wrote:Dutch_12078 wrote:
Does the generator keep running if you hold down the start switch? If it does, that indicates that it's not putting out enough voltage to the control board to lock in the run cycle. It could be a faulty voltage regulator ($$$), or it could be dirty slip rings. Holding the start button down for a minute or two may clean the rings enough to keep it running. Worth a try anyway...
No. will run ,but as soon as I release button, the engine stops.
Does it keep running as long as you hold the button down? Even for a minute or longer? If it does, it's not an engine problem, it's an electrical problem...
