KMLsquared
Jan 19, 2021Explorer
Kennyg wrote:KMLsquared wrote:
That fuel solenoid will stick closed not allowing fuel to enter the main jet. The reason it runs briefly is because the automatic choke is on enrichening the fuel air mixture, compensating for the lack of fuel going thru the main jet. Any water in the float bowl sits on the bottom and in that solenoid causing corrosion in a short time. I just fixed an Onan with the same issue.
When I disassembled the carb and manually moved the solenoid plunger it moved without restriction.
If I bypass the solenoid will the engine start as long as I use the jumper?
No, the only way to "bypass" it would be to take plunger out of it. The spring keeps it closed until power is applied to it. If you apply 12VDC to it on the bench you should be able to test it.
Did you make sure the holes in the brass piece were free and clear?
