Kennyg
Jan 19, 2021Explorer
KMLsquared wrote:Kennyg wrote:KMLsquared wrote:
That fuel solenoid will stick closed not allowing fuel to enter the main jet. The reason it runs briefly is because the automatic choke is on enrichening the fuel air mixture, compensating for the lack of fuel going thru the main jet. Any water in the float bowl sits on the bottom and in that solenoid causing corrosion in a short time. I just fixed an Onan with the same issue.
When I disassembled the carb and manually moved the solenoid plunger it moved without restriction.
If I bypass the solenoid will the engine start as long as I use the jumper?
No, the only way to "bypass" it would be to take plunger out of it. The spring keeps it closed until power is applied to it. If you apply 12VDC to it on the bench you should be able to test it.
Did you make sure the holes in the brass piece were free and clear?
Yes I did. Used carb cleaner as well as air hose to clean. Can see thru all the holes and the air passes thru all of them.
On one utube video, it talks about another "Brass" fitting with holes that is up in carb. The more I think about this is this piece which the solenoid pushes up and down?
