ndrorder
May 15, 2021Explorer
whemme wrote:jyh818 wrote:
Are you below 1/4 tank of gas in your RV. I think it prevents you from using the generator if your RV fuel tank is below 1/4 tank.
If that was true the generator would not even start and run for 15 seconds. Problem sounds to me that you may have a defective Onan fuel pump.
Not exactly. There is about 15 seconds of runtime worth of fuel in the carb bowl when it is full. Without 1/4 tank or more or with a failed fuel pump, then the bowl wouldn't be replenished.
