More_To_See
Feb 02, 2014Explorer
There is a 30 amp fuse feeding that compressor, etc.
Open up your fuse box on the driver's side in the engine compartment and look for a 30A fuse shoved in there on the far side to the right as you are looking at it. It's just shoved in there sort of as an after thought.
If that fuse is ok, go back to the compressor and unplug, clean, reconnect the connectors back there.
38,782 PostsLatest Activity: Sep 10, 2026
