flphil
Feb 02, 2014Explorer
Thanks MTS. Checked fuse and fuse is good. Do you know if there is a way to manually inflate the bags. I have filled the air tank manually to 120 lbs. Just need to get the solenoids/valves, whatever it is to let the air in the bags. I will definitely look at connections once I can get it out of the street.
38,782 PostsLatest Activity: Sep 10, 2026
