turbojimmy
Feb 08, 2014Explorer
BigRabbitMan wrote:
I have a suspision that you are correct in that you did not give it enough time to build pressure. Pressure builds slow at first as it must double the volumn in the tank to double the pressure which from a start would get it to 15 psi which is not much.
Yeah, it would take a while to fill all that volume and build up pressure. I only let it run for a few minutes. I'll have to try it again when I get the new engine in it. The electrical system is all unhooked currently.
In any event, it's a neat system and very well engineered.
38,782 PostsLatest Activity: Sep 10, 2026
