turbojimmy
May 05, 2014Explorer
Got the new pump installed. Since there is no replacement pump from Jet Co or otherwise that fits the stock bracket, I moved the pump inside under a bed. It worked out perfectly because the storage area under this bed is directly above where the old pump was:
Using the schematics from the original Jetco literature I wired up the 40-amp relay that came with the new pump. Basically it's this:
- The original Jet Co blue wire from the ignition feed gets installed the same way: through the pressure switch. The other side of the pressure switch controls the relay that runs the pump.
- Replaced the bulky old solenoid with a 40-amp relay
- Tiny black wire from the Jet Co harness is spliced into the blue ignition wire - it feeds power to the soleniods
- You can use the original Jet Co constant hot, but it my opinion it was grossly undersized for a 15-amp draw and 35-foot cable run. It had obviously been getting hot. I ran a new 4-gauge cable with a 60-amp circuit breaker. This will protect the electric motor, too, by making sure it has the appropriate voltage.
- Hook the tiny purple wire from the Jet Co harness to the pump's hot wire - this lights up the "COMPRESSOR RUNNING" light on the control box.
- The new pump has 3/8" fittings. Needed about $25 in brass fittings to adapt to the original 1/8" Jet Co lines and to install the new pressure switch.
- New pump and relay can ground at the original spot on the Jet Co bracket
The pump works FAST. And my air horns work now too!
38,782 PostsLatest Activity: Sep 10, 2026
