homerbw's avatar
homerbw
Help! Stuck in Arkansas
Our M/H is a 2000 Fleetwood Pace Arrow Vision 36B. As we were traveling, the electricity would go off. We stopped at a repair center in Conway, AR. and they need to replace the Power Tek model PDC 1009 automatic transfer switch and energy management system which is no longer in production and they don't know how to procure one. Help! Anyone have any idea where we can order this?
  • Bruce, I found this post; http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24267003.cfm
    Should answer most of your needs. Like I said call Randy.
  • Bruce, I would suggest that you call Randy at 888-828-1893, his web site is bestconverter.com. Explain your problem and he will let you know what you need to replace your old unit. I am not sure if you have a power management system or a PDC, power distribution system. I've got a feeling what you need is a transfer switch and distribution panel. Normally the distribution center can be used if you replace the transfer switch. Like I asked earlier, is the part you need the fuse and circuit braker panel?
    Call Randy and talk to him. When I bought a new converter for my electrical, he gave me detailed instructions and drawings for the changeover. Delivery was very fast and he may ship express, I don't remember. He'll need to know if you have a 30 or 50 amp service and model of stuff that needs replacing.
    Good Luck and if you need help or moral support, PM me and I'll give you my phone number or call you.
    Dave
    PS; Colaw RV's number is 877-548-2123 and they have some PowerTek stuff for sale.
    PPS; Reread your reply, and I think all you want is the transfer switch. If this is correct by a new one from any RV supply shop or call Randy and ask him to send you a PD 5100 or 5200 series switch for either 50 or 30 amps whichever you have.
  • I am not very good with electrical but the transfer switch has two contacts that engage the shore power or the generator power. It is a black square block with wires in the power distribution box. This is the same box that houses the circuit breakers and the 12 volt fuse panel.
  • As far as I know a xfer switch is a xfer switch, any RV shop should be able to replace that. I'm not sure what you are calling an "energy management system".
    If you mean a distribution panel, same answer.
    I googled PowerTec model pdc 1009 and no help. Post a picture or give a more detailed definition.
